right turn signal
Old Jul 1, 2011
nexis's Avatar
nexis is an unknown quantity at this point
right turn signal
hey guys after seeing how smart everyone is, id like to know whats wrong with my right turn signal. i replaced it a while back cuz it had burned out. i put in a new bulb the exact same kind, but now it blinks atleast 2X as fast as my left signal. any ideas as to what it is?
thanks so much guys
Old Jul 1, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: right turn signal
does the back one blink on the passenger side
Old Jul 1, 2011
nexis's Avatar
yes both the front and year turn signal blink but they are sped up from how they originally were
Old Jul 13, 2011
illrohan's Avatar
illrohan is an unknown quantity at this point
There might be some difference in the bulb. Usually when u install LED's they blink faster. They draw such a low voltage that the ECU thinks they are burnt out. Maybe it's the same size bulb and base but only 6 volts instead of 12, or less watts. Hope that helps.
Old Jul 14, 2011
nexis's Avatar
i checked both of the bulbs and the are the exact same voltage. the new one isnt a LED.
Old Jul 14, 2011
CraigW's Avatar
Try the new bulb in the other side and see if the problem follows the bulb, double check the original and the new bulbs actual #s
To re: LEDs draw a low current... and ECU and turn signals ??
Old Jul 14, 2011
nexis's Avatar
so i just swapped the bulbs over to test it. and they are both blinking faster than they should be. all connections are correct. bulbs are the exact same just one newer than the other.
Old Jul 14, 2011
CraigW's Avatar
Your flasher unit may be failing...? How do the 4 ways work ??
Old Jul 14, 2011
nexis's Avatar
everything is working fine except for the bulbs themselves it seems.
Old Jul 14, 2011
CraigW's Avatar
How does it act with the 4 way flashers switched on ??
Old Jul 15, 2011
nexis's Avatar
with the 4-way flashers turned on all the lights are blinking at a uniform speed like they would with no problem. but when using just the right turn signal it still blinks too fast
Old Jul 16, 2011
CraigW's Avatar
Whats the year of the car ??
Old Jul 16, 2011
lazlong's Avatar
Start by pulling the steering column covers off and inspect the wires and connection at the combo switch (turn signal switch). It's either the combo switch itself, a bad wire between the combo switch and the turn signal, or a bad ground.
You can also download the manual and diagnose it yourself with a multi-meter.
Old Jul 16, 2011
nexis's Avatar
its a 1991 hatchback. like ive said there are no loose wires first thing i checked. the old bulb worked fine before it burned out.
Old Jul 16, 2011
CraigW's Avatar
So you are using #1156 bulbs ??
Old Jul 16, 2011
lazlong's Avatar
Like I said- download the manual and diagnose the combo switch
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
