1992 civic keeps failing etest!!!
Old Oct 16, 2011
BigSlice00's Avatar
BigSlice00 is an unknown quantity at this point
so i have had my civic in and tested 4 times in the past 2 weeks and the NO PPM number continues to increase regardless of what i have done.
recent work i have done is...
cat
o2 sensor
exhaust from cat back
retarded the timing
fresh oil
premium gas
new plugs, wires
i have been reading all these little tricks and tips to pass this portion of the etest but cant seem to find anyone saying what works....
my reading is 1500 and the limit is 636 for NO ppm in Ontario
Any help with this would be appreciated
Thank you
Old Oct 18, 2011
BigSlice00's Avatar
Re: 1992 civic keeps failing etest!!!
nobody??....
suggestions?...
Old Oct 18, 2011
MindBomber's Avatar
Live for the Twisties
Cut a big hole in the exhaust out of site from visual inspections.
jk
94 octane or premium fuel is of no benefit, in fact, it is probably working against you. The compression in your engine is to low to completely burn the fuel. Use regular gas and mix a 0.5 liter of methyl hydrate into the tank. If your cat isn't functioning then you won't pass, there's no way around that.
Old Oct 19, 2011
Civic_Nightmare's Avatar
FTP
Civic_Nightmare is an unknown quantity at this point
pcv valve?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
cloudguy
Apr 28, 2015 05:02 AM
kevin99ek
Apr 23, 2015 09:32 PM
gabrown2
Apr 11, 2015 08:22 PM
