1995 civic ex vtec. overheating please help
Old Oct 16, 2011
cquimby93's Avatar
cquimby93 is an unknown quantity at this point
the car does multiple things i hate.
it overheats. and when this happens the car then steams a **** load out of the radiator area.
the heat has stopped working
also the car idles really high. like 1500 rpms.
and then once it warms up it revs up and then dies and then revs back up. repeats.
i am thinking about replacing the etc thermomater, the head gasket the idler and the timing belt.
tell me what you guys think.
i need help with all of the things above.
can you please help me. detailed instructions. a step by step if you will
Old Oct 16, 2011
95civic123's Avatar
95civic123 is an unknown quantity at this point
Re: 1995 civic ex vtec. overheating please help
u could have a cracked head are u losing any power at all
Old Oct 16, 2011
cquimby93's Avatar
i dont know. i may have,
how hard would it be to replace the head..
and what are some signs
Old Oct 16, 2011
tildeath's Avatar
tildeath is an unknown quantity at this point
Ok first off take out the spark plugs see if theres any fluid on top of the pistons. if so you need a head gasket.
#2 for the high idle check your Idle Air Control Valve.
#3 Check see if your losing Fluids any were. Make sure you have fliuds in your radiator.
You can send me a Private pm i can help you step to step on solveing these issues.
Xuhme
21
Aug 7, 2023 03:40 PM
beneditti
Jan 15, 2016 12:31 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
silvervtec01
Nov 4, 2001 06:56 PM
