Can't remove front LCA bolt
Old May 12, 2011
ezknight's Avatar
ezknight is an unknown quantity at this point
I'm replacing the front LCA bushings on a 1994 Civic EX. Drivers side went off without a hitch. On the passenger side the rear bushing bolt and mount brackets were not an issue. I moved on to the front LCA bolt. the threaded insert welded on the inside of the crossmember piece is broken off and the bolt just spins. Would cutting a small hole to get access to the other side of the bolt possibly be a safety issue?
Old May 12, 2011
Re: Can't remove front LCA bolt
vise grips, as thin as possible. I had the same issue. if that does not work, cut a window...
Old May 12, 2011
MindBomber's Avatar
Live for the Twisties
Cutting absolute last resort.
Torch. Pb blaster and vice grips.
drill, easy out.
Drill, helicoil install are all better imo.
Old May 12, 2011
ezknight's Avatar
I was afraid as much, but it never hurts to ask. If I have to cut a hole, I can weld the piece back in when I'm done. Thanks for your help.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
GolNat
Sep 10, 2015 08:25 PM
Flipg123
May 22, 2015 10:43 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Grey
16
Jan 27, 2002 11:34 PM
