Question? i need help
Old May 21, 2011
sidekick's Avatar
sidekick is an unknown quantity at this point
Question Question? i need help
hey i have a 95 civic dx and i have been having problems and not sure what it is..if u can help id appreciate the advice well heres my problem
my car has jus started to over heat and also i believe my throttle position control sensor is going bad but now my car is hard to start n then it will heat up n stall and wont start it tries to turn over but it wont start and when it does start the car will turn over and then it will start to shake right before it starts does anyone have an idea why?
Old May 21, 2011
MelJ's Avatar
Trance Addict
Re: Question? i need help
Sounds like the symptoms of a head gasket failure. I'm on my phone, so I have limited internet privileges. There's an FAQ floating around. Use the search feature with key words like overheating, head gasket, etc.(don't use etc. Haha)
Edit. Thankfully this topic is heavily discussed here and this thread was actually a few threads down so I could snag the link. Thanks sdaj!
https://www.civicforums.com/forums/3...reference.html
Old May 21, 2011
lazlong's Avatar
Although it sounds like it's the headgasket (hard start, stalls and won't run do to coolant in the cylinders) I would check for codes also as sensor could be throwing it off too: http://check-engine-light-codes.blog...retrieval.html
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
