94 Civic EX...issues :(
Old Apr 25, 2011
Lexter's Avatar
Lexi Lynn
Lexter is an unknown quantity at this point
Unhappy 94 Civic EX...issues :(
So I just changed my oil a few days ago, drove my car 3 hours up north, then 3 hours back a couple days later. I was driving home from work, started turning a corner and my car stopped running. Now It won't start. I don't know anything about cars but I REALLY want to learn. It sounds like it's going to start when I try...but it just doesn't. I just had the O2 censor replaced, timing belt, exhaust. What could be wrong with it now I need advice! Any ideas?
Old Oct 11, 2011
civicdane850's Avatar
civicdane850 is an unknown quantity at this point
Re: 94 Civic EX...issues :(
check your fuel mine is acting really strange too i hard wired my fuel pump bc it would just stop working whenever ... and now my injectors are not working so i hope this helps if you already figured out the issue tell me what was wrong it may be the same issue with mine lol thanks
Old Oct 29, 2011
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
When you turn key to on position (not start) can you hear a hum from the back seat (fuel pump). If not change main relay down where you pull the hood release. This is good place to start and they are only about 20 bucks. After that i would check distributor cap and rotor.
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
