d16z6 Number 1 Fuel Injector leaking.
Old Jul 9, 2011
Awluiz's Avatar
Awluiz is an unknown quantity at this point
Alright, so my number one fuel Injector is leaking, i was driving and started smelling gas, i got home, turned my car off, popped my hood and smelled straight gas, looking for wet spots and everything, and it was obviously dried up, i turn my car on, and low and behold gas is just dripping fairly fast out of my number one fuel Injector, i suspect it's the o ring, and i need to replace it, because other than the smelling of gas, it runs perfectly fine, now on to my question. Does anyone have a guide to removing the fuel rail and replacing the fuel injector o rings? I lost my book as i was moving last week. Any help is appreciated so I can get this done asap.
Old Jul 9, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: d16z6 Number 1 Fuel Injector leaking.
its honestly straight forward , just take the clips off of the fuel injectors and then remove the fuel rail and the injectors should pull right out and when u replace the o rings make sure u dont pinch the o rings then u will have to do it all over again
Old Jul 12, 2011
Awluiz's Avatar
Does anyone know the size of the O-Ring for the fuel injector it is? What the dimensions of it is? Because that's my only problem, i was able to get my hands on 2 sets, and i need 3, i tried an o ring they found for me, but it was just not thick enough, and it still sprayed but in a different bore. I just need to find an o ring for it. And if i can get the size of it, i could probably find it easily.
Old Jul 15, 2011
turbo_coupe_EJ1
just go to autozone and ask they should have the right size
alxz310
Jul 30, 2015 12:18 PM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Causemo
Jul 5, 2015 06:42 AM
