Locate ECT sensor 1992 VX
Old May 9, 2011
2EcuriouS's Avatar
2EcuriouS is an unknown quantity at this point
Locate ECT sensor 1992 VX. Have been informed to try replacing this because my VX doesn't want to start without a small squirt of gas in intake if it sits for awhile (evidently cooling off). Is there any procedure or setup after replacing this sensor. I also have reduced mileage which could be contributed to this sensor. It affects the setting of injectors stroke I guess.
Thanks - 2EcuriouS
Old May 9, 2011
MelJ's Avatar
Trance Addict
Re: Locate ECT sensor 1992 VX
I would start by testing the sensor first before you start replacing stuff. Check the condition of the wiring. You should be getting about 5 volts from the PCM to the power and ground wires. As for the location, you may have to search here or on Google to get a wiring diagram to help you out.
Old May 9, 2011
lazlong's Avatar
It's in the thermostat housing kinda below the distributor. It has 2 wires.
But first check for codes: http://check-engine-light-codes.blog...retrieval.html
Old May 11, 2011
2EcuriouS's Avatar
Thanks lazlong. Good information. Good link to chk eng light blog too.
2EcuriouS - Locate ECT sensor
Old May 11, 2011
2EcuriouS's Avatar
Thanks for the volt chk info. Think I have it located. One is fan sw and the other is a thermister.
mohawkboom
67
Aug 25, 2015 12:28 AM
brielle
May 31, 2015 09:24 PM
Rushfan1
May 6, 2015 01:20 PM
wh3nw0rdsesc4pe
Feb 28, 2002 01:37 AM
vasilli69
Feb 20, 2002 05:24 PM
