1995 Honda EX - Car begins to shake when in first gear
Old Oct 22, 2011
pileish123's Avatar
pileish123 is an unknown quantity at this point
Hi All,
First time poster here and I dont know much about cars. I have a 1995 5 speed manual Honda Civic EX with 156K miles on it.
Recently when starting from a fully stopped position, the car will begin to shake when I go from neutral to first gear and try and take off. The shaking feels like it is going to stall out unless I give it more gas.
What kind of problem can be the cause here? I am not new to stick so I dont think its how I am shifting. Could it be transmission? Clutch?
The guy at EZ Lube mentioned I could need a tune up as it could be to low idling.
Thanks for any help.
Old Oct 22, 2011
pileish123's Avatar
Re: 1995 Honda EX - Car begins to shake when in first gear
41 views and no replies?
Old Oct 22, 2011
MelJ's Avatar
Trance Addict
I dunno, mounts? Is your clutch slipping while accelerating? I'd think if the car needed a tune up, it would just run rough in general.
Old Oct 29, 2011
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Mine does the same thing. Famous problem for this generation, it becouse of the hydraulic clutch, it is the first year they used it and they didn't get it quite right. What I do is just let out the clutch quickly and jack rabbit start. You will squeel the tires sometimes but you won't get the shuddering.
Old Sep 23, 2019
beneditti's Avatar
beneditti is an unknown quantity at this point
Mine does the same thing but its not always. Like Kellog mentioned above, probably just the hydraulic clutch. If yours does it excessively everytime then you might have something else wrong.
Old Sep 23, 2019
Colin42's Avatar
Thread is 8 years old
EdtheChipmunk
Jun 19, 2015 10:37 AM
LayinLo
Jan 7, 2006 07:09 AM
DaSilverCivic
Feb 15, 2005 07:41 PM
scsGrumPyDriveR
Jun 30, 2002 04:19 PM
ATLCIVIC
Jun 19, 2002 11:51 AM
