Help with 97 Civic EX manual
Old Jun 19, 2015
EdtheChipmunk's Avatar
EdtheChipmunk is an unknown quantity at this point
Okay so I bought a 2 door civic ex. I replaced the Clutch because it was beyond bad. It ran fine for a few days and then the Slave clutch cylinder blew so I replaced Both the Master and the Slave clutch Cylinder. Now, It will run but wont go anywhere. By that I mean the gears are there but I have no Pick up from 1st through 5th. For example I took it on the highway and it took me two exits to get to 55 mph. Reverse seems like it's a little high on the RPM side but it seems to work fine. So I ask what could possibly cause this?
Before I forget, I noticed that when I start the car and put it in first, then take my foot off the clutch it continues to run even though it should stall out. What would cause that to happen?
Any thoughts or ideas are greatly appreciated. At this point I'm completely at a loss. I was thinking possibly the linkage, but if it was the linkage it wouldn't be able to be put in gear right?
Old Jun 19, 2015
GolNat's Avatar
Prelude Owner
Re: Help with 97 Civic EX manual
Almost sounds like the clutch is slipping really bad. Popping the clutch should cause it to stall so if it's not its is almost like it is not engaging.
When the clutch is pressed does it go into gear smoothly?
Old Jun 19, 2015
It shifts smoothly. Doesn't feel hard in anyway. Yesterday I was shifting gears with 1 finger. It just doesn't seem like it wants to go anywhere. I have no burning clutch smell. However when I shift into first gear or any gear for that matter it revs high. In some cases close to 7k. Like I said in the above post it just doesn't want to go anywhere. Doesn't matter how much gas i give it.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
C6GrandSport
Apr 25, 2015 09:41 PM
cooldan1
Apr 23, 2015 10:49 AM
chirp the 1-2
Apr 19, 2015 02:19 PM
