Strut tower housing cracks. Fixable?
Old Jun 27, 2011
jacktfrost's Avatar
jacktfrost is an unknown quantity at this point
Question Strut tower housing cracks. Fixable?
94 Civic EX. Previous owner installed coilovers and then evidently decided to drive over speed bumps at high speed all day.
Im just wondering if it's possible to weld the cracks or if there is another solution. Thanks!
http://imgur.com/8hTv7
Old Jun 27, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: Strut tower housing cracks. Fixable?
is it where you bolt in the struts
Old Jun 27, 2011
jacktfrost's Avatar
Check the link to the pic. Its outside that area.
Old Jun 27, 2011
turbo_coupe_EJ1
well if nothin is warped or bent then a good weld should get it but u will have to get the right penatration on the weld cause if u dont then the weld will break
Old Jun 28, 2011
BlueEM2's Avatar
Whachya lookin at?
Someone did some overtightening there. Is it a physical crack in the steel or is it the paint cracking??? It's hard to tell in the picture. Don't drive the car like that if you like being alive cuz that shiz is dangggerous. Take it to a body shop and get a suggestion from them... err... Tow it to a body shop.
Old Jun 29, 2011
jacktfrost's Avatar
Its a physical crack. Also the metal has separated from the material below it.
Old Jun 29, 2011
BlueEM2's Avatar
Whachya lookin at?
Tow it to a body shop. Don't mess with this if it does fail it will be bad bad bad bad bad bad bad bad...
Old Jun 29, 2011
ow! ow! ooooowch!
take to a shop and have them look at it... might even need a chassis pull...
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
