PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : [1] 2 3 4 5 6 7 8
  1. Engine swap nightmare
  2. 84-87 Instrument Cluster Interchange
  3. 85 4wd
  4. Suspicious engine Knock
  5. Can I swap a S20 B000 tranny with a S20 A000 without having to change axles
  6. Electrical lighting issue.
  7. HELP! Timing job 1994 civic D16Z6
  8. SRS light on always
  9. 1992 civic VX transmission rebuild questions
  10. D16A9 whining noise
  11. L15B2 Oil Light flickers
  12. 1990 Ef Ignition Problems
  13. Car struggles to idle, is it an injector problem?
  14. Jumping throttle on small input and 2.5-3.5K RPM throttle on slightly larger input
  15. Rear Window Defrost
  16. Dizzy problems....
  17. Should I get adjustable upper control arms?
  18. Did I check my camber correctly? PLEASE HELP
  19. 93 DX map sensor & throttle body
  20. Vacuum line help
  21. 89 Dx civic Vacuum line help
  22. Help! Civic cranks but won't start
  23. Not so good vibrations
  24. Electrical repair
  25. Remove CVCC auxiliary combustion chambers?
  26. 1989 DX Idle Air Control Valve
  27. integra rack on eg civic
  28. Stuttering problem 92 hatch
  29. 91 Civic LX radiator steam but no overheat?
  30. is replacement ECU plug n play? /remove cat?
  31. No power to ecu
  32. d16z6 Crank, No spark, No fuel
  33. 94 Civic Cranks, No Start, Coolant Loss Post HG Replacement - Seeking Insight!
  34. 93 ex is still overheating after head gasket
  35. Engine Timing
  36. 1977 top strut mounts
  37. My EG still keeps farting after replacing the IAC valve..
  38. rebuild the rack & pinion or buy a new one
  39. 95 Civic DX - laundry list
  40. Tranny falls out of 2nd gear in a hard right turn only!
  41. Leaking fluid underneath transmission?
  42. 95 CX 276,000 miles, no start [solved?]
  43. Help with heater valve
  44. Tourqe specs?
  45. Car won't move when put in gears after car was towed away due to not having a valid l
  46. Running rich, black smoke and poor acceleration
  47. 1993 replaced clutch now will not go into any gear? [solved]
  48. 1993 Civic LX 4-door Rear Driver Door stuck
  49. crank no start,someone please help!!
  50. Dome light circuit question
  51. D16Z6 operating temperature
  52. Idle issues, loss of brake pressure
  53. Parts Question 1990 Civic DX
  54. EGR valve delete kit legit?
  55. Fuel pump not priming
  56. 89 Si rough idle and no attempt from car to start the engine
  57. ID of metal box on pass side wall forward of door?
  58. 95 CX parts [solved]
  59. 89 Civic Wagon died [cause found]
  60. Patching up cabin wiring harness, need diagrams PLEASE!?
  61. Ignition Coil Isn't Working! (1989 1.5L)
  62. 95 civic wiper issue
  63. Oil Leak Mystery
  64. 2000 watt inverter installation
  65. d16z6 block Y8 head
  66. Ej2 d15b7 run,s terrible
  67. Civic EJ1 RPM gauge goes crazy [solved]
  68. 92 dx ecu not priming fuel pump Ic17 issue?
  69. 1994 Civic Transmission Problems
  70. Swapped Civic Won't Start
  71. 93 civic parts
  72. Eg with y8 no crank
  73. My accessory stopped working I can't shift out of park, the car won't start [solved]
  74. Stock steering wheel to horn connection
  75. Newbie here looking for some advice.
  76. shifter rod wobbly
  77. Ignition cylinder woes
  78. Mystery brake fluid loss
  79. Louder than usual at 45mph
  80. Gauges not working
  81. No power with new battery.
  82. Fixing '94 Civic DX Hatch
  83. D15b7 high surging idle
  84. 95 civic ex 1.6L Automatic Shift woes
  85. Odd problem: Dist shaft not normal.
  86. 93 ex cranking
  87. Randomly died but is fine now
  88. Battery Issue
  89. dash cluster lights
  90. Dash Cluster lights on a ‘92
  91. Battery Issue
  92. Distributor from japan
  93. timing cover 1983 civic
  94. Need replacement rear bumper cover
  95. 2 barrel carburetor float adjustment without site glass
  96. Parts 1991 honda civic hatch DX
  97. Won't go into gear
  98. Are you looking for parts for very old civics?
  99. Car sounds like motorcycle
  100. 1994 ex D16
  101. 93' ex not starting
  102. 1979 Honda CVCC Question
  103. Losing/Regaining Power Mid Throttle
  104. Intro and question for a 93 Civic Ex
  105. 95 Honda Civic Tail Lights
  106. 1989 cx hatch exhaust leak
  107. 5th gen civic high mileage HG
  108. ebrake does not engage on passenger side
  109. drum brake self-adjuster mechanism
  110. 89 civic fuse panel wiring!Help
  111. Ignition slot next to gear shift?
  112. 1989 Honda Civic Driving Issue
  113. 1980 Civic Wagon Anti Siphon plate/plug
  114. 1980 Civic side rear view mirror
  115. 1986 Civic sedan 1500cc fuel pump replacement
  116. Best ecu for non vtec b20b
  117. Car slows down while going up a hill
  118. Rpm distributor wire
  119. Seat Harness Help
  120. 87 Honda Civic SI Throttle position Sensor
  121. Harness Bar for 93 Coupe
  122. Secondary fuse box problem
  123. Ignition timing, 1982 2nd gen
  124. 89 Civic won't start..I'm lost!
  125. Car stalls when i press the brake.
  126. Replace inner tie rod end boot?
  127. car continues running with key to Off
  128. turn signals acting as brake [solved] - led without resistor
  129. brakes go to floor, new master cylinder didn't help.
  130. Compatible ECU's for '94 honda civic DX?
  131. MAP sensor engine when driving to puddles.
  132. 1989 PCM-Fi fuse keeps blowing
  133. 89' Civic Wagovan, no spark, fuel, ecu, power to main relay
  134. Sputtering and hesitation when accelerating
  135. bogged down after throttle replacement
  136. PA State inspections - odometer rules
  137. Question
  138. On/Off Engine Sputtering 95 Dx
  139. Need a rear seat for a 81 Honda civic 1300dx
  140. when replace rear wheel bearings?
  141. adapter for floor jack
  142. 95 Honda civic speedometer problem
  143. No Injector Pulse - '95 B18 (non-Vtec) swapped EG Hatch -
  144. 1994 Civic Si fuel+spark=no start?
  145. Low Mpg -- Straight Pipe/O2 Sensor?
  146. Low idle and Overheating
  147. Re: BAD vibration between 28-40 mph
  148. Crank pully/harmonic balancer
  149. ECU timing
  150. OBD0 ECU pins
  151. Rough idle and dying ECU
  152. intermittent limp mode fix?
  153. 93 Civic LX codes 41 and 43
  154. 1992 Civic Hatchback Glass
  155. 1983 Civic 1500 DX no spark help
  156. 87 Civic dies when warmed up. Won't start until significantly cooled down.
  157. Front right hose
  158. Do I Need New Clutch Parts?
  159. Please help 1995 civic low compression back to stock issue
  160. Leak under radiator
  161. 94 hatch engine/light surge
  162. More Confusion Because of Swap
  163. Weak spark 1987 honda civic si
  164. 93 hatch gsr swap not starting
  165. My Honda Civic woun't start at all...
  166. 1995 Civic - Gas Pedal Hard to Press
  167. 94 honda civic sedan body matching
  168. NEED HELP. Electrical questions 91 ef hatch
  169. No Crank on a 1991 Civic Si Hatch with a ZC 1.6L SOHC Non-V Engine
  170. Wire came out of the ecu pin
  171. Civic 1992 5th Gen Si - Car Won't Rev after 3000 rpm when it's warmed up
  172. Looking at buying a '81 5 speed Civic Wagon! Help needed!
  173. 91 DX, rear oil seal. Should I do it?
  174. 95 civic ex coupe , b18c1 gsr swap
  175. ECU identification
  176. Does ECU Year matter?
  177. Car Won't Start! - Seeking Advice!
  178. 89 civic dx engine light help
  179. 92 si hatch won't start
  180. What is this plug for?
  181. Meaning of Cel Flashing?
  182. randomly cutting off then starting no warning
  183. Manual transmission interchangeability
  184. New Caliper Again? Banjo Bolt? Stuck Clutch Pedal?
  185. 1992 Honda Civic D15b8 Idles low and loses power when warm [solved]
  186. sputtering
  187. BAD day tranny swap question
  188. 94 Honda Civic si
  189. 91 civic 1500cc fuel delivery problem ..throttle body
  190. Rear seat removal
  191. D15Z1 P07-1 cam holder number 5 valve cover bolt mount fractured
  192. Should I Replace or Fix Ignition Distributor?
  193. Check engine light comes on Rpms and power drops HELP!!!
  194. 94 Civic Ex no crank no start (Intermitten Power Loss)
  195. weird shifting
  196. First Start In A Year
  197. 95 civic DX distributor 8-wire connector
  198. Civic EG (EH9) Heating no to warm
  199. I have a crank no start '95 civic.
  200. 95 Honda Civic won’t start
  201. Gringing noise only when in gear around 2800 rpms and higher
  202. Fuel pressure drop long start crank
  203. 1992 Speedo turns on after long drive
  204. Crank bolt from hell
  205. 1993 Honda civic DX Crank but no start
  206. 1988 Honda Civic DX issue
  207. 1993 honda civic engine problems
  208. Ecu question
  209. Does anybody know what sensor this is???
  210. Temperature gauge isn’t working, Fan isn’t kicking on either.
  211. 1991 honda civic dx main relay failed one of 3 continuity tests what to do next
  212. Won't stay crunk...
  213. connects to?
  214. hood fitment question
  215. Need Rebuild ideas and suggestions
  216. Illumination not working
  217. Head Gasket or Heater Core
  218. 93 Civic LX driver's power window and locks don't work
  219. '94 EJ2 headlights living a life of their own?
  220. Seat Cover Recomendations for 91 Civic Si?
  221. Clicking/Clanking/Clunking Not a good sound 1988 CRX
  222. Butterfly valve stuck -- any advice?
  223. 1990 Honda civic dx hatchback Idle issue
  224. ?turbo? Issues, engine chugs when turbo spools high or at high speed
  225. 95 Civic 5spd not starting.
  226. 92 VX D15B Idle surge
  227. 93 DX HB, sometimes battery needs jump
  228. A/C idler rattle
  229. 1988 Civic CRX 1.5 quit running
  230. Transaxle or clutch problem?
  231. Stuck in limp mode
  232. Rough idle when warm after valve cover gasket / noisy new pulley
  233. Will d17 axles fit d16?
  234. Puzzling Brake Problem
  235. Fuel leak from ? Fuel pressure regulator 1992 Honda civic sedan
  236. 1988 Civic CRX
  237. Wont run after Maintenance
  238. 1995 Honda Shift Lock
  239. ‘95 Civic VX needs exhaust manifold California emissions.
  240. 1986 Honda Civic Wagon Idle Issues
  241. 94 Civic EX Power Window off track
  242. Engine overheated, and I fear the worst...
  243. 1989 Honda Civic Si 1.6 B16
  244. 95 Honda Civic wont start
  245. Transmission drain and fill--No fluid came out (94 EX)
  246. '94 VX won't start. Dink-Donk noise
  247. 1994 civic lsi coupe- Water in the spare tyre boot well
  248. bleeding coolant and a geyser occurs
  249. Front left window regulator, Civic 5th gen 1995, help
  250. Multifunction switch
