1993 replaced clutch now will not go into any gear? [solved]
Old Aug 12, 2023
FFD123's Avatar
FFD123 is an unknown quantity at this point
Transmission servicing is good clutch has been bled slave cylinder seems to be in place ,working alone so I can't see if it's moving. And have checked most things mentioned in previous posts.
Old Aug 12, 2023
Colin42's Avatar
re: 1993 replaced clutch now will not go into any gear? [solved]
Pull it apart and check your work
Old Aug 12, 2023
FFD123's Avatar
Thank you for responding but that won't be necessary actually looked up on another website that has nothing to do with Honda Civics. The problem that I don't remember being mentioned anywhere was that my master cylinder needed to be adjusted inside the car where it connected to the pedal so there is more throw. So I adjusted it out about three turns and everything works as advertised. Thanks again it was definitely a very simple fix.
Neilcivic
Transmission
Apr 24, 2022 12:01 PM
Phoenix LSX
Transmission
Nov 10, 2018 05:30 PM
Knuts34
Oct 11, 2016 05:00 AM
dsmoore
16
Mar 18, 2016 08:33 AM
crowgo
Buy, Sell, & Trade - Archive
Jan 5, 2010 12:44 PM
