Engine Timing
Old Dec 24, 2023
Travisg1990's Avatar
Travisg1990 is an unknown quantity at this point
Engine Timing
Hello everyone. Going to give brief instructions on how to check engine timing since I cannot find clear instructions elsewhere.
If your engine has jumped time (meaning the crankshaft and camshaft are no longer in sync) you will see poor performance, low engine power, misfires, check engine light. And that's if you're lucky enough to only have jumped a few teeth. If the belt snaps or the tensioner completely gives out you're looking at bent valves, an engine that won't start, and a lot more work.
To check timing follow these steps:
1: Jack up and remove the front left tire.
2: Remove the ignition coils and spark plugs.
3: Find the crankshaft pulley (behind the inner splash panel in front left wheel well). Using a 19mm socket rotate the engine counter clockwise until the timing marks align. Never rotate clockwise or you could cause it to jump time. This position is referred to as TDC (top dead center).
4: Now you need to remove the upper timing belt cover. To do this you need to either remove the valve cover or loosen it enough to pull the cover out from underneath. There are three bolts holding the timing cover, you will also have to unplug the camshaft position sensor.
5: Once that has been done you should now see the camshaft. Verify the timing marks look like the below.
6: If the "Up" mark is pointing down use 19mm socket to rotate the crankshaft counter clockwise one rotation until its mark lines up again. The reason for this is the crankshaft rotates twice for every one rotation of the camshaft. Once this is done the "Up" mark on the camshaft should then be pointing up. Verify the timing marks on the camshaft match the above.
7: If they do not match verify the crankshaft is still aligned properly. If it still doesn't match then the engine is no longer timed correctly and will need a new belt/tensioner. Do not start or crank until this is fixed to avoid additional damage. If the marks are nowhere close the damage may have already been done.
I do not have a car sitting in front of me while writing this so if anyone has any additions feel free to add.
I had air in my coolent pushing coolent out of car I replaced everything and said what the hell and I did a new head but now it will not start timing looks good got to tell you I messed up should have set to dead center before removing anything lesson learnd.. i need help i tryed to put #1 pisston to top and marks barley match like a tooth off of mark did not start put the marks togeather did not start i need help
Old Dec 25, 2023
BrotatoChip's Avatar
Super Moderator
Re: Engine Timing
Post some pictures of your timing marks.
Ayesha151971
May 15, 2023 10:09 AM
BrotatoChip
Engine DIY
May 30, 2019 01:41 PM
onedr
Nov 12, 2017 05:48 PM
autotech2go
Sep 28, 2012 11:44 PM
number4t1
Buy, Sell, & Trade - Archive
Mar 25, 2010 11:00 AM
