Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
'91 Civic Won't Start
Old Sep 19, 2007
number4t1's Avatar
number4t1 is an unknown quantity at this point
This is quite a saga, but I'll try to be breif..... Without prior indication of problems, by 'Vic died on me on the way to work - just shutoff at highway speed and would not start.
I thought it was the fuel pump. Changed that - no luck.
Changed the ignition coil - no luck.
Changed the ignition module - no luck, but something changed. Before, the engine just turned over and wouldn't start. Now it turns over a few times, then I get a "poping" sound like it is backfiring out of the air intake, but still never starts.
I have spark on all 4 plugs. I have fuel (based on the smell of gas when trying to start). I have no error codes on the ECU LED display. I don't know where to go from here. The timing belt and tensioner were changed about 15K miles ago, so I initially ruled out timing as an issue. Now I am not so sure. Any ideas on what else to try before tearing into the timing belt?
Old Sep 19, 2007
lemac's Avatar
lemac will become famous soon enough
Re: '91 Civic Won't Start
Sounds like the timing belt jump a few teeth. I would tdc the engine and double check the timing marks on the cam gear, just to rule it out for sure... God luck with it
Old Sep 20, 2007
number4t1's Avatar
What is the easiest way to tdc the engine? I am working on this by myself.
Old Sep 20, 2007
lemac's Avatar
There should be a timing mark on both the timing cover and the crank pulley. Rotate the pulley using a 19 or 21mm socket, I forget which one. You might have to clean the edge of the pulley to find theses marks usually a white or red dash. Line the timing mark up with the mark on the timing cover. It would be best to get a Haynes Repair Manual it will be able to give you details way beyond what I can plus pictures to help guide you through. But if you want to continue then proceed to take of the valve cover after you tdc. If you have the marks lined up at the bottom then when you look at the cam gear it should have four dots along the rim, to tell if it is in its right position it should read at on of its dots (top) or an arrow. The other two dots should line up with the top of the head on each side of the cam gear and the last dot pointing down. Before you make your final decision double check your timing marks at the bottom and the ones at the cam gear, if you find out that indeed you need to make adjustments hit me up again and I'll try to guide you through the best I can. Good luck.
Old Sep 21, 2007
number4t1's Avatar
Thanks for your help! Turnes out I just had #3 & #4 plug wires crossed. (Duh!) I must have done that when I changed out the ignition module. She's running like a champ again!
Old Sep 21, 2007
lemac's Avatar
Congrats... thats alot better.
Old Sep 24, 2007
CiViCPrAnInG2k1's Avatar
nice, good to know this problem worked out well... HAIL TO THE CIVICS!!!! bwuahahahhaa
Old Oct 18, 2007
number4t1's Avatar
OK, I'm back again. The car has been running great since I fixed the ignition module and the crossed plug wires....that is until today. It started up fine this morning and ran fine all the way to work (about 56 miles). When I eft work this afternoon, it wouldn't start - same as before I changed the ignition module. It turnes over fine, but just won't start. I wnet to check the error codes on the ECU, and found that it does not come on at all when I turn the key to the "On" position. I am assuming that this is the root of my problem. How do I go about trouble-shooting this?
Please help! It costs me $20/day to drive my jeep to work, I need to fix this fast!
Old Oct 18, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
the ignition coil - Does it have a brown liquid coming from it when you unplug the sparkplug wire from it? (when it stalls out on the highway, roads, etc...)
Old Oct 19, 2007
number4t1's Avatar
No. everything in the distributor is clean. Actually the car started up this morning like nothing was wrong. ECU powered up with no error messages. Someone suggested that it might be a bad relay. Where to start checking?
Old Oct 19, 2007
lemac's Avatar
Could a bad ground cause this??????? This is primarily a question more than a answer.
Old Oct 22, 2007
eviee1973's Avatar
eviee1973 is an unknown quantity at this point
Check the pgm main relay by the steering cloumn, it switches power to the fuel pump and the ecm. When the get worn out, they still function intermittently, similar to what seems to be going on with your car
Old Oct 22, 2007
lordhelmet's Avatar
There is a fuel pump relay under the dash up near the fuse box. My sisters 92 civic had the same problem (wouldnt start all the time). I would check that first.
Old Mar 25, 2010
tnator81's Avatar
tnator81 is an unknown quantity at this point
Hi Guys, I joined because my 92 civic is doing a similar thing. i have bypassed the main relay, nothing, replaced the distributor, nothing, hooked the fuel pump straight to power, nothing. it ran all winter no problems and yesterday, no start at work. once the wife got to work to pick me up, it started just fine. it is driving me nuts.
Jonnie.
Jan 13, 2019 11:21 AM
vtec92
May 4, 2017 03:20 AM
Braun
Apr 23, 2015 09:03 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
