89 Civic won't start..I'm lost!
Old Mar 4, 2022
Chrondog's Avatar
Chrondog is an unknown quantity at this point
Hello! Im having an issue with my 89 civic. I'm getting fuel.. I'm getting spark(not sure it's enough to start it) I'm thinking it might be an issue with my spark.. I've replace wires and plugs as well as ICM... it started out having problems with being tough to start and once I turned if off it wouldn't start again...another thing I noticed is that a good portion of my fuses under the dash aren't testing as ..When it was starting I found having the gas pedal to to floor would help.. if anyone has aby insight on what it might be I'd appreciate the help...really need my car for work..
Old Mar 4, 2022
BrotatoChip's Avatar
Super Moderator
Re: 89 Civic won't start..I'm lost!
Meaning a bunch of fuses are bad? That could cause some issues.
Old Mar 5, 2022
Chrondog's Avatar
It's not a bunch bad fuses, I checked them with a meter and just to be sure I even put some new ones in and same problem.
Old Mar 15, 2022
87Si's Avatar
87Si is an unknown quantity at this point
Make sure plug wires are on right Check firing order on distributor.
Xxmsfxx
Feb 10, 2020 01:59 PM
co2wen
Jan 16, 2019 05:50 AM
Civicbtch
Jul 29, 2018 04:13 PM
Soulie
Oct 24, 2013 08:52 PM
kbc6313
Nov 23, 2011 06:39 PM
