Car starts, won’t start or just shuts off while driving
Old Jul 28, 2018
Civicbtch's Avatar
Civicbtch is an unknown quantity at this point
I own a 2000 Honda Civic Si, with a turbo charger. I’ve been having this issue for several months, had a MSD ignition, thought that was the problem, so I replaced it, ran good for a few days, then it started doing the same thing again. Took out the MSD completely and put a on brand new distributor, plugs and wires, once again did good for awhile. Then it started acting up again, had a reader put on it and it spit out 5 codes, only really worried about one of them, the MAP sensor, so I bought one, stopped somewhere before going home, came back to the car and it wouldn’t start, changed the MAP sensor, and it fired right up, now I’m thinking problem solved, not so much. Driving to work the very next morning and it shuts off on me going down the street, I kept trying to start it and after about 5 minutes it started, so off to work I went. I have days where it starts and I make it to work but then after work it won’t start. My man works on it for me and he’s checked all the wires under the dash and they’re all good, sometimes he works on it for several hours and other times it’s like 10 or 15 minutes and it starts. Thursday it wouldn’t start so he was messing with the wires, then he had me push my alarm button 5 times, and it started, so crazy. Any help on this matter is greatly appreciated.
Feeling Frustrated
Civicbtch
Old Jul 29, 2018
mac25's Avatar
Dr Krieger of Modification
Re: Car starts, won’t start or just shuts off while driving
Ya good luck with that.
lol
There are soooo many possible causes that it's impossible to help you at this point.
You need to track down which major issue is not functioning. AIR, FUEL OR SPARK.
Air flow shouldn't really be an issue so its fuel or spark.
Once youve found which one you will need to trace back every component which would cause that issue including the modified parts like whatever you used to tune the car.
Check all grounds, fusses, and relays
Start at the spark plugs and test for a strong spark.
test the fuel pressure
test the ignition pulse signal
check the timing
Look at the a/f ratio
After you've done this you should find the issue. Now that you now the issue you can troubleshoot the cause.
Old Jul 29, 2018
Colin42's Avatar
Ignition switch? Remove the alarm system?
patrickross2017
Apr 8, 2018 01:25 PM
dkrege
Dec 19, 2012 07:55 AM
kbc6313
Nov 23, 2011 06:39 PM
swpowe
Dec 26, 2009 05:21 PM
Michalo187
Oct 10, 2005 11:52 AM
