92 dx ecu not priming fuel pump Ic17 issue?
Old Jan 18, 2023
BillsMafia85's Avatar
New Member
BillsMafia85 is an unknown quantity at this point
92dx not getting fuel pump to prime, but take a hair dryer to the ecu and it runs fine...is it the c17 doohickey? If so where/what part to buy to solder new one in?
Old Jan 19, 2023
Wankenstein's Avatar
Re: 92 dx ecu not priming fuel pump Ic17 issue?
Here's a related post from the HT site https://honda-tech.com/forums/honda-...-work-3109898/
If the fuel pump relay is not the issue then you'll have to remove the ECU (disconnect battery first) and open it up to inspect the capacitors for bulging and/or leaking. The link above mentions C14 capacitor. Where did you find info that it's C17?
Notice the circuit board in the video below it has labels for capacitors (C), resistors (R), and other components by their respective number(ex: C14)
Your ECU may have developed condensation or even a leak somewhere on the body may be causing it to get wet? Inspect for bulging or leaking capacitors and if you don't see anything obvious the use a hair dryer to blow dry the ECU circuit board. Afterwards spray it with Deoxit
Amazon Amazon
This alone might solve the issue.
While the ECU is out use a hose to spray your car down from the top to see if there is any water intrusion near the ECU.
Take pics of the ECU board and post them here if you have any questions.
If you find any bad capacitors their uF and voltage (ex 33uF/100 volts) rating will be written on them. Do a search online to find a replacement. This might help https://www.google.com/search?q=92+9...client=gws-wiz
Courtney Glass
Mar 1, 2021 06:59 AM
McD
Apr 22, 2015 05:28 PM
searen4
May 18, 2010 11:32 AM
bond007
18
Jan 30, 2003 07:41 PM
Raslin
Oct 26, 2002 12:02 AM
