Sponsored by:
Sponsored by: CARiD
Jackson Racing High-Output Fuel Pump
Old Oct 23, 2002
Raslin's Avatar
Raslin is an unknown quantity at this point
Hi everyone im new to this site but doesnt any know if the Jackson Racing High-Output Fuel Pump would help with the returnless fuel system in our civic's?
Old Oct 23, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
You're gunna need more than a new fuel pump to change our returnless fuel system. No fuel is reutnred back to the tank meaning it will all be used up.. Our stock pump is more than plenty to pump fuel, its just you're gunna need new fuel lines, ECU upgrade, new injectors, all kinds of stuff besides the pump...
Old Oct 23, 2002
Raslin's Avatar
thanks for the info
Old Oct 23, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
im curious, if there was a way to control the fuel pump better then the stock ecu, or an upgraded pump for that matter, wouldnt the problem of the returnless system be eliminated? if we could send the exact amount of fuel needed to the motor at that sepecific time, then wouldnt that work?
humm [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 24, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: mwwhonda
humm [IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
Exactly! Actually, the ECU (ECM) does a very good job of delivering fuel. It controls the fuel pressure as well as the injector pulse width to produce the optimum spray pattern (from the fuel injectors) at any rpm. If we could just program the stock ECU (ECM) for upgraded injectors and an upgraded fuel pump and FPR (Fuel Pressure Regulator) then we'de have the fuel system problem solved.
Better yet, being able to control boost pressure via a boost controller and an external wastegate and being able to tune down the amount of fuel that's delivered would allow us a perfect control of light boost for cruising and high boost for racing. This is my goal with my turbo. I want it to be extremely usable. I don't want to buy something that only works at a certain horsepower setting.
Hopefully a company like Hondata will release all we need to do this sort of ECU (ECM) programming. I have my fingers crossed at least...
Old Oct 25, 2002
nongv's Avatar
nongv is an unknown quantity at this point
well wouldn't the aem one work like what you are saying?
Old Oct 26, 2002
Grey's Avatar
DIY King
I believe so. It's a lot of money though. Probably worth it if you're dead serious about performance though.
mistermenphis22
Jul 13, 2015 04:43 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
1khilari
Jul 9, 2015 08:12 PM
Bounddyy
Jul 8, 2015 11:22 AM
fvckbg
Jul 7, 2015 07:08 PM
