Meaning of Cel Flashing?
Old May 8, 2021
Nvisi's Avatar
Nvisi is an unknown quantity at this point
So I randomly get a CEL while driving and with the paper clip in the cel just does a short flash once over and over I thought this meant code 1 02 sensor A and I replaced that, but the code still comes back. Can somebody tell me what this code means if I was wrong?
Old May 8, 2021
FRSam's Avatar
Click Here
Re: Meaning of Cel Flashing?
Does it flash without the paperclip in? Flashing normally indicates a misfire.
Old May 8, 2021
Nvisi's Avatar
no it doesnt flash without the paper clip in when the cel comes on while driving it just stays solid and when you turn the car off and back on it usually doesnt come on untill a little later on. With the paper clip in then it just flashes quickly once over and over
Old May 8, 2021
Nvisi's Avatar
also u helped me with the last problem I had lmao, you guessed it it came back so im trying to investigate the cel it gives to see if thats pointing me in the right direction.
Old May 8, 2021
Colin42's Avatar
Go buy a scanner for $20 and post the actual code number
Old May 8, 2021
FRSam's Avatar
Click Here
It'll do something like a series of slow flashes, followed by a series of quick flashes. You need to count them which will correspond to a code (i.e 4-3, 4 being slow flashes and 3 being quick flashes)
Old May 8, 2021
Nvisi's Avatar
yeah I did that all it flashes is once quickly over and over
Old May 8, 2021
Nvisi's Avatar
didnt know they even made those for obd1 that would be a big help ill pick one up
Old May 8, 2021
Nvisi's Avatar
I feel like it has something to do with the connection the 02 sensor has to the ecu but I have no idea how to even check that. Ive tried going to the ecu and pushing the wires down to make sure there in all the way lmao but im not sure how to check if my ground or something like that is bad.
Hayden_Fourroux
Nov 16, 2014 09:32 AM
carlosdee
Sep 12, 2014 10:48 PM
Levi likes si
Jun 28, 2013 11:38 PM
civ_nate
Jul 19, 2007 10:13 PM
gotti
Nov 11, 2004 09:30 PM
