car continues running with key to Off
Old Feb 24, 2022
blackdog48's Avatar
blackdog48 is an unknown quantity at this point
Hello,
I have recently been having an issue where my car continues running with the key turned to Off. It as though I have not turned the key (engine runs, etc.). What can cause this issue? Thank you All,
blackdog48
Old Feb 24, 2022
Re: car continues running with key to Off
broken wires or connectors
Old Feb 25, 2022
blackdog48's Avatar
Thank you sdaidoji,
Is there one in particular on the pigtail harness behind the lock cylinder that I should look at?
blackdog48
Old Feb 25, 2022
FRSam's Avatar
Click Here
Typically it’s caused by a bad ignition switch or fuel pump relay.
How have you been shutting off the car?
Old Feb 25, 2022
blackdog48's Avatar
It has only happened twice, and I pulled the 7.5 amp fuse for the ECU. Thanks,
blackdog48
Old Feb 25, 2022
FRSam's Avatar
Click Here
Maybe your ignition switch is shorting intermittently. Cannot say for certain, though.
Old Feb 25, 2022
Maxpeedingrods's Avatar
Former Sponsor
Maxpeedingrods is an unknown quantity at this point
I have seen a alternator’s voltage regulator do something like this on an a very old model car...but I would suspect the ignition switch first
Old Feb 25, 2022
blackdog48's Avatar
Hi Chezboat24,
This shows how little I know about the ignition system, I'm sure, but would a faulty ignition switch not keep my car from starting? Thanks again All,
blackdog48
Old Feb 25, 2022
FRSam's Avatar
Click Here
It depends on why it's faulty. Worn contacts, for example, will stop it from functioning. It sounds like there's a short somewhere which keeps giving the ignition power, which may explain why the car continues to run.
Old Feb 25, 2022
blackdog48's Avatar
OK, I think that makes sense to me. Is there a particular wire that I could hook up to a kill switch if I have difficulty sorting out where the short is?
blackdog48
Old Feb 25, 2022
i would first open it up before wondering
Old Feb 26, 2022
Colin42's Avatar
You can get a new switch for pretty cheap.
Do some testing before throwing parts at it though
Old Feb 26, 2022
blackdog48's Avatar
Fair enough guys. I think I get pretty apprehensive about electrical issues. I will take a voltmeter out to the garage, though, and see what I can find out. Thanks.
maxtierney
Electronics DIY
Sep 5, 2022 07:25 PM
maxtierney
Sep 5, 2022 07:23 PM
nweber911
Oct 21, 2012 02:13 PM
shaamlee
May 28, 2010 08:30 AM
philboy81
Nov 24, 2009 06:16 PM
