Should I get adjustable upper control arms?
Old Jan 24, 2025
Rfishi's Avatar
Rfishi is an unknown quantity at this point
I was in a wreck and my camber seems off now. I am going to replace the upper control arms, but should I get stock ones or get adjustable ones, so I can make sure the camber is fixed? It looks like the adjustable ones hold the ball joint in place with two small bolts, but I've heard of it coming loose and sliding. Anyone have experience with these?
Old Jan 26, 2025
Rfishi's Avatar
Re: Should I get adjustable upper control arms?
If something else is bent causing negative camber, can I just get the camber kit to fix it?
Old Jan 27, 2025
That's kinda what I did on my 2002. Had a camber kit (adjustable upper arms) anyways because I was lowered and adjusted it to correct the camber issue that was caused by subframe damage.
Will it work? yeah. Advisable for a permanent fix? Probably not. Will it last a while? I had no issues running with that subframe damage and corrected camber for 3+ years, so
Old Jan 27, 2025
Rfishi's Avatar
My subframe bent enough to do this to the left motor mount. Do you think I would be okay just correcting the camber, or should I just get a new subframe (not really in budget)?
Oleschool
Nov 24, 2014 04:57 AM
silver-n-black
Apr 14, 2014 09:31 PM
Ironliftr3
Oct 13, 2012 07:16 PM
fulltimeride
May 12, 2004 05:02 PM
SleeperCivic
Nov 7, 2002 10:50 PM
