1992 civic VX transmission rebuild questions
Old Jun 15, 2025
JUdahbuddah's Avatar
JUdahbuddah is an unknown quantity at this point
Hello everyone, i have some questions about rebuilding my 92 VX transmission, as well as some other questions. Would I be able to take gears 3 and out of a DX/LX/Del sol S transmission and put them into mine? all these gears are a bit closer and im curious if I can just swap them in. I also want to swap in the 4.058 Final drive, Would this be possible? And would it be possible to switch these gears out of transmissions for the D16 engines?
My goal is to have closer gears like my 95 del sol S had while still being able to drive on the highway without being so high in the rpms like I would be with an civic SI 5th gear and final drive (I'd honestly like to put in the fifth gear from a CRX HF to have a very long fifth gear ). So I figured might as well just rebuild my transmission and change the gear ratios and final drive and im wondering if this is possible, thank you
If this isnt possible then I plan on getting a used transmission and rebuilding it, I assume the tranny's on the D16 engines will mount up to mine but can anyone confirm or deny this? And would it just mount up or would I need different shifter linkage?
Thank you all, anything helps! I dont know a ton about transmissions but im trying to learn
Old Jun 16, 2025
FRSam's Avatar
Click Here
Re: 1992 civic VX transmission rebuild questions
d-series.org will be a much better resource for this sort of situation.
beezelbub
Transmission
Aug 2, 2022 07:05 AM
DavidRey
Mar 18, 2012 02:14 PM
hypnotic7thgen
Jun 9, 2009 04:28 PM
Civic_2NER89
Mar 5, 2006 09:26 AM
WannaBFast
May 14, 2003 02:06 AM
