Help. Civic is popping out of 5th gear. [solved]
Old Jul 28, 2022
beezelbub's Avatar
beezelbub is an unknown quantity at this point
Question Help. Civic is popping out of 5th gear. [solved]
My civic is popping out of 5th gear going up slight hills, and now even on a flat surface. It seems it has gotten worse. I realized it feels like the shift handle isnt going all the way into gear when it is on the ground. However, It goes all the way in gear when I lift the car up with a floor jack and the tire is not on the ground. I am confused. Is it the rear engine mounts fault?
Old Jul 28, 2022
FRSam's Avatar
Click Here
re: Help. Civic is popping out of 5th gear. [solved]
If the engine is moving a lot, potentially. Have someone rev the car and see how much it flexes.
Could also be something like a synchro going. 3rd gear is the more common one but I've seen 5th as well.
Old Jul 28, 2022
inspect the mounts and see if they are broken. Like said above, check it the assembly is moving too much.
Note: the shifter uses cables, not a hard linkage
Old Jul 28, 2022
beezelbub's Avatar
Its missing the top bolt of the rear t mount and i can't find a replacement. It is longer than the bottom two but every diagram says it is the same size as the bottom one.
Old Jul 28, 2022
Colin42's Avatar
Go to the dealer, or a junkyard for the bolt
Old Aug 2, 2022
beezelbub's Avatar
got a bolt at a hardware store and changed the oil and it works now. There was very little oil in it.
ryan7472
Transmission
Mar 19, 2022 11:35 PM
MLG-SQUIDWARD
Mar 25, 2018 04:33 PM
grey2k11
Jul 23, 2016 01:55 PM
1llmatic
Engine Swaps
Oct 12, 2004 05:58 PM
Miami240
Apr 19, 2004 12:03 PM
