More Confusion Because of Swap
If I need to replace both the clutch slave and master cylinders in my 5th gen hatchback that has a b18b motor swapped in, would I need to get the cylinders for the civic or for the model of integra the motor came from?
If I need to replace my driving axle (front right), would an oem civic one fit into the transmission on the b18b, or do I need to find an integra axle because of the different size transmission and possibly different teeth?
Sorry if some questions I ask on here are common knowledge amongst the community here, but I'm completely inexperienced when it comes to motor swapped cars.
Re: More Confusion Because of Swap
Master cylinder should be the civic, slave might be civic, probably Integra. I would compare part numbers on rockauto. Axle needs to be a b series axle I believe. So should be an integra axle
natedog37
Jan 11, 2013 05:15 PM
rayvnicolas
Nov 11, 2010 12:12 AM
94civichatch
Aug 12, 2010 02:27 PM
