95 CX 276,000 miles, no start [solved?]
Old Sep 2, 2023
knuckledragger's Avatar
knuckledragger is an unknown quantity at this point
I have had a recurring problem that I thought was fixed by replacing the fuel pump, then the FP relay. Now it cranks and seems to have no spark. Will replace old plugs, but doubt that will fix anything. Where now do I look? Main relay?
Old Sep 2, 2023
Colin42's Avatar
re: 95 CX 276,000 miles, no start [solved?]
Need to see if the coil and igniter are good in the distributor
Old Sep 7, 2023
Turns out the ECU was not working. I pulled the battery cables for a half hour or so, and it started right up again. I know this is not a permanent fix, so I need to find a good ECU and have it programmed.
Old Sep 10, 2023
Re: 95 CX 276,000 miles, no start [solved?]
Is there anyone who rebuilds ECUs here? I found a post on fleabay that would rebuild and reprogram my bad one for $190
Old Sep 11, 2023
FRSam's Avatar
Click Here
Not that I'm aware of. Worst case, a local junkyard should suffice.
Old Sep 25, 2023
Bad news. The ECU rebuilder in Illinois could not fix it, so I am now looking for a used ECU and hope it will plug and play.
OR
The ECU number is 37820-P05-L02 This fits and is programmed for 1995 civic with 1.5 engine and manual trans.
Old Sep 25, 2023
FRSam's Avatar
Click Here
OR
I believe it's plug and play, so you should be in luck there. Won't be too hard to find. I'm expecting there to be tons around from people who engine swapped theirs.
Old Sep 26, 2023
Colin42's Avatar
Local junyars or ebay should be able to find one
olson23849
Feb 4, 2010 08:46 AM
opto_isolator
Engine Swaps
78
Sep 25, 2004 05:23 PM
mad_stylz36
Aug 12, 2003 02:26 AM
zelman
20
Sep 5, 2002 11:50 AM
