85 4wd
85 4wd
Newby here.
I'm trying to figure out the part I need for the vacuum hoses and switch to go from 2wd to 4wd.
My mechanic talked me into a new carburetor and pulled all the vacuum hoses including the 4wd! And he pulled the switch wiring which I don't understand...
Thanks!
Thanks!
Re: 85 4wd
The hoses should just be regular vacuum hose in whatever size the fittings are. The switch you might have to contact honda for a part number and then try to find something compatible.
Re: 85 4wd
If someone has a picture of the vacuum solenoid switch I would appreciate seeing it. I believe it's located on the passenger side, on the firewall where the vacuum tubes are located going in to the transmission.
Thanks
Thanks
