Accesory Switch
Old Jun 21, 2004
player's Avatar
Accesory Switch
i want to have an Accesory switch, a switch which i can flip to activate all my car accesories even if the key is not in, how exactly do i do this ?
thanks
Old Jun 21, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
what kinda of car accessories? aftermarket stuff you installed or the radio?
Old Jun 21, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Couldn't he just run a switch in parallel with the switch on stearing column?
Old Jun 21, 2004
it all depends the current demand of the accesories
Old Jun 22, 2004
WhiteRabbit's Avatar
go out and buy a switch, single pole single throw will do, install it somewhere in the car with two leads coming off traveling to the steering column, 14 gauge or better.
open the steering wheel column, drop down teh wires aroudn the ignition, you will see a black wire with a red stripe, and a black wire with a yellow stripe. tap these two wires with yoru two, doesnt matter which to which.
flick the switch, and all your accessories come on! watch yoru battery level.
if it doesnt work, whoops, I meant white wire with red stripe, not black wire with a red stripe. retap (yellow t-taps work well here) and try that one instead.
robjcivic
Mar 12, 2017 12:10 PM
MamaBear2015
49
Sep 29, 2015 01:12 PM
Klame9420
Sep 7, 2015 10:03 PM
junkyardguy
Sep 2, 2015 06:07 PM
dtdoyle
25
Aug 30, 2015 06:57 PM
