95 Civic 5spd not starting.
Old Jul 1, 2020
parvs's Avatar
parvs is an unknown quantity at this point
I have a 95 Civic Sedan DX D15B7 engine that won’t turn over. it sounds like it wants to start and then just dies. i have replaced distributor, fuel filter, fuel pump, spark plugs, spark plug wires. i’m absolutely lost at this point.
Old Jul 1, 2020
GolNat's Avatar
Prelude Owner
Re: 95 Civic 5spd not starting.
Battery okay? You said it won't turn over.
Old Jul 1, 2020
parvs's Avatar
yea forgot to add that the battery is new too
Old Jul 2, 2020
FRSam's Avatar
Click Here
Have you checked timing?
Sounds like a project. Have you had this running at any point before?
Old Jul 2, 2020
parvs's Avatar
no tbh i don’t know how to. after replacing distributor it started but would hesitate like it wasn’t getting gas to the motor. so i replaced the filter and pump and still nothing. now it won’t even turn over and let me gas it or anything.
Old Jul 2, 2020
FRSam's Avatar
Click Here
So there's no cranking at all after changing fuel pump/filter?
Timing sounds plausible here, but check a few things before getting to that point.
Engines need 5 things to run: air, fuel, spark, compression, and timing. Safe to assume that spark and compression is okay. Is the fuel pump priming when you turn the key? Is the intake getting vacuum? (Remove intake and feel for suction. See if it'll run on starter fluid if there is suction).
If it runs on starter fluid, it's still a fueling issue.
Old Jul 2, 2020
parvs's Avatar
this is currently what it does. it has ran on starter fluid before but obviously not for long. which is why i replaced the pump and filter. i will have to find the starter fluid again to try it so i’ll have a look. fuel is priming when i turn the key i can hear the pump turn on. there is pressure at the engine to my knowledge.
there is also fuel pressure at the intake
File Type: mov
Old Jul 3, 2020
GolNat's Avatar
Prelude Owner
Did you mark the distributer and put the new back in the same spot? You could have thrown off the timing when replacing that. You can adjust timing by turning the dist. CW or CCW
Old Jul 4, 2020
parvs's Avatar
the engine turns on but doesn’t stay running on starter fluid
Old Jul 5, 2020
Wankenstein's Avatar
Try starting it with gas pedal fully depressed to the floor. Test or replace fuel pump relay and main relay:
Ktel7
Sep 13, 2018 08:45 AM
GucciGavin
Nov 11, 2017 12:13 PM
Luckycat1
Oct 25, 2017 08:36 PM
fauxmason
May 13, 2013 01:26 PM
z6coupe
Dec 20, 2009 03:15 AM
