95 lx no start-NEED HELP!
Old May 13, 2013
fauxmason's Avatar
fauxmason is an unknown quantity at this point
got a 95 lx that turns over fine but just won't start. I put the spark tester to it and got spark on all 4 cyl. The dist. appears clean, timing belt is turning fine. Checked compression and all 4 were between 70 and 95 psi. Tried starting fluid and it did nothing. I have replaced the fuel filter and with the nut cracked I get plenty of fuel moving through with the key turned. No lights are on (check engine, etc.). I parked this thing for a week in jan. and when I went back to start it got nothing. Someone please help!!
Old May 13, 2013
Re: 95 lx no start-NEED HELP!
You say there is spark. Is there enough spark? How long of a lightning bolt will it throw, and are you checking this at the ends of the plug wires?
Are the spark plugs wet with fuel?
Is the cam/crank in time?
