Tranny falls out of 2nd gear in a hard right turn only!
Old Sep 21, 2023
civicms's Avatar
civicms is an unknown quantity at this point
I have searched all over Google and can't find an answer or direction.. Please help if you can..
Issue:
After a recent transmission rebuild 2nd gear is falling back into neutral but ONLY when in a hard right turn (autoslalom). Doesn't matter on or off throttle, it falls out. If you hold the shifter during the corner it will stay in gear.
1989 Honda Crx
Cable Y1 manual transmission
Recently rebuilt (new syncros, rings, sleeves, bearings etc..) - full rebuild kit from Syncrotech.
Linkage seems okay, clutch feels fine, replaced the motor mounts... I don't want to jump right to tearing the transmission apart again. I drained the fluid and there is no metal in it. If it is internal, I don't understand why it would only be effected when cornering..
If anyone has any insight or faced the same issue please help.
Cheers,
Michael
Old Sep 22, 2023
Re: Tranny falls out of 2nd gear in a hard right turn only!
cable alignment?
Old Sep 22, 2023
Colin42's Avatar
Bad engine/trans mounts?
Old Sep 22, 2023
civicms's Avatar
That's what was first suspected. I have innovative poly mounts. Replaced them with new inserts but still having the same issue.
01em2ex
Transmission
Dec 10, 2019 08:44 PM
RafBys629
Feb 20, 2015 02:34 PM
joe_honda
Feb 16, 2009 01:49 AM
csbball13
Aug 23, 2006 10:25 PM
BasicEssentials2k1
Feb 17, 2004 01:37 PM
