Rear defogger power clips
Old Oct 4, 2011
pinch's Avatar
pinch is an unknown quantity at this point
1992 Civic LX: How do you remove the power clips attached to the rear window defogger? Press the button, pull on the wire? Press the button, pull on the black plastic shroud?
I'm getting power to rear window, but think I need to clean the power clips and re-insert them to make good contact. I am confused how to work the black plastic cover around the clip. It says "PUSH" on it. Because of the tight quarters, it is challenging to access the clips. I'm concerned if I get too physical I might separate the clip from the window.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
Mercilus
Jun 7, 2015 10:00 PM
Flipg123
May 22, 2015 10:43 PM
