stuck crank bolt
Old Sep 16, 2011
batman010208's Avatar
batman010208 is an unknown quantity at this point
stuck crank bolt
hello iv got me a 92 honda civic 4 door and iv got a problem the crank shaft pully as come loose and cant tighten or loosein to fix any thing i can do
Old Sep 16, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
Re: stuck crank bolt
heat it up and take a good impact to take it off
Old Sep 17, 2011
lazlong's Avatar
A lot of times an impact won't do it. Hit it with penetrating oil the night before. Block the flywheel from turning. Then use as big a cheater bar as you can find on your breaker bar. I use a fence post and stand on the radiator support and fender and crank on that sucker as hard as I can. If that won't do it, get an extension long enough to come outside the fender so as to get better leverage.
Brandon Vlasak
Jul 25, 2015 07:25 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
ballmich
Jul 9, 2015 11:59 AM
