1989 Civic hatch Main relay ?
Old Oct 26, 2011
hondarider17's Avatar
hondarider17 is an unknown quantity at this point
http://manitoba.kijiji.ca/c-cars-veh...AdIdZ324925378
Im looking at getting this civic.
I dont know much about electrical.
he says the main relay is bad, what does that mean? how do i test it? is it an easy fix etc? can you guys inform me a bit!
thanks in advance!
James
Old Oct 27, 2011
tildeath's Avatar
tildeath is an unknown quantity at this point
Re: 1989 Civic hatch Main relay ?
here you go check this out
http://honda-tech.com/showthread.php?t=2535047
Old Oct 27, 2011
lazlong's Avatar
Sorry, wrong thread.
Old Oct 29, 2011
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
go to rockauto.com or ebay , you can get a new one for 20 bucks
Old Oct 31, 2011
tdbaker156's Avatar
tdbaker156 is an unknown quantity at this point
ok basically when you go look at the car a way to test the main relay is to touch it or hold it in your hand and when you turn the car to the on position you should feel a click. and the same when you turn the key off. if it doesnt then the relay is bad. they arent hard. its mounted under the dash dy the fuse panel with a 10mm bolt and then just unplugs, it will take maybe 5 min to change out.
Jonnie.
Jan 13, 2019 11:21 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
chirp the 1-2
Apr 19, 2015 02:19 PM
BREADFAN
Apr 15, 2015 08:58 AM
