Vtec swapped for d15b7
Old Apr 13, 2015
Pr0n1s's Avatar
Pr0n1s is an unknown quantity at this point
I bought a 93 Honda Civic coupe and it idles really high. 1100 rpm and vin says it has a 1.6 crew but it rly has a d15b7 and a s20 transmission. I have a vaccuum line on the tbi that's just hanging with a bolt in it and I can't find a map sensor please help me if anyone can
Old Apr 29, 2015
davidpaustin's Avatar
davidpaustin is an unknown quantity at this point
Re: Vtec swapped for d15b7
Believe it or not I've done the same thing with one of my vacuum lines. It's just an easy way to plug a vacuum line that is not needed. Of course I am also running an after market Intake Manifold. Just over 1000 rpms is not too terribly high. It sounds like you might need to double check the timing. Even loosening the distributor and turning it slightly counter clockwise might do the trick. Your map sensor should be located right on top of the throttle body.
Old Apr 30, 2015
Pr0n1s's Avatar
the car seems to be missing the whole harness for a map sensor is my main issue now I thought I could find it but no luck so far. But retarding the timing should help a bit right?
Old Apr 30, 2015
Every now and then I have heard of people relocating the map sensor and they usually attach it to the throttle body with a vacuum line. Also, every now and then I have seen it located on the firewall as shown in this link.
http://www.ff-squad.com/tech/sensors/map.firewall.jpg
Kevinsisco
Aug 31, 2015 12:04 AM
Bonnabell
Aug 14, 2015 04:15 PM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Trennytrent
Jul 10, 2015 09:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
