Civic smoking bad
Old May 26, 2014
Jeckel595's Avatar
Jeckel595 is an unknown quantity at this point
Civic smoking bad
89 civic ex hatchback 158,000 miles smoking bad has had new valve seals
Has 155 to 162 psi in each cylinder hot cold was 160 across board need help can't seem to fix it
Old May 26, 2014
Re: Civic smoking bad
Smokes worse as the RPM goes up: Rings.
A compression test cannot evaluate oil control rings.
Old Jun 26, 2014
Larry21603's Avatar
Larry21603 is an unknown quantity at this point
My 84 Civic started smoking and burning oil. I did the bit with valve seals. Didn't work. Did Auto-Rx and it stopped for a while. Finally I pulled the engine and rebuilt it because as a smoker it would not pass Cal smog. Everything inside was in great almost like new condition. The problem was that the oil control rings gave up. I was fooled too because the compression was at new car specs and the engine ran great, no drop in gas mileage, just sucked up a lot of oil.
Old Jun 26, 2014
Thanks for validating my statement!
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
