94 civic ex smog fail
Old Oct 15, 2014
ronhill's Avatar
ronhill is an unknown quantity at this point
I just bought it and tried to smog it and failed. i didnt get a print out because the guy didnt want to charge me. i have no check engine light on. Any suggestions? i just drove it from AZ. to CA. on less than a tank of gas 388 miles. It misses a little on idle otherwise runs great
Old Oct 16, 2014
Poopies's Avatar
Super Moderator
Re: 94 civic ex smog fail
You should get your OBD1 scanned for free at an auto parts store like Autozone. If you're lucky, it's just a bad downstream 02 sensor. At worst, your catalytic converter is on its way out.
Old Oct 16, 2014
ronhill's Avatar
doesnt the check engine light have to be on for there to be codes ? i checked timing was fine bought cap, rotor, plugs, air filter. i read somewhere about using propane for vacuum leaks and found almost all my lines were leaking. replaced them. now idle is low like 450 rmp. i disconnected the iac and tried to adjust idle and it does nothing. help
Old Oct 16, 2014
Poopies's Avatar
Super Moderator
Not necessarily. Sometimes it shows up after a few cycles. I mean, you can keep firing the parts cannon at it or you can get the computer checked out for free in case it's something simple. Your call.
Old Oct 16, 2014
ronhill's Avatar
alright thanks for the help. i have a feeling ill be posting alot more
Old Oct 18, 2014
ronhill's Avatar
it passed with flying colors must of been all the leaks
mistermenphis22
Apr 3, 2016 08:06 AM
Fastfebur
Apr 26, 2015 11:57 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
mugenca
Apr 16, 2015 12:15 AM
gabrown2
Apr 11, 2015 08:22 PM
