94 civic ex smog fail
I just bought it and tried to smog it and failed. i didnt get a print out because the guy didnt want to charge me. i have no check engine light on. Any suggestions? i just drove it from AZ. to CA. on less than a tank of gas 388 miles. It misses a little on idle otherwise runs great
Re: 94 civic ex smog fail
You should get your OBD1 scanned for free at an auto parts store like Autozone. If you're lucky, it's just a bad downstream 02 sensor. At worst, your catalytic converter is on its way out.
doesnt the check engine light have to be on for there to be codes ? i checked timing was fine bought cap, rotor, plugs, air filter. i read somewhere about using propane for vacuum leaks and found almost all my lines were leaking. replaced them. now idle is low like 450 rmp. i disconnected the iac and tried to adjust idle and it does nothing. help
mistermenphis22
Apr 3, 2016 08:06 AM
gabrown2
Apr 11, 2015 08:22 PM
