Dizzy Leak
Old May 17, 2015
davidpaustin's Avatar
davidpaustin is an unknown quantity at this point
Dizzy Leak
I know this has been talked about before, but after searching many times and hours, I was wondering if anyone has another alternative to fix the common oil leak in the Honda distributor leak.
I have replaced the O-ring 5 times and tried 3 different distributors and still have a pretty significant leak. I've thought about constructing a gasket between the dizzy and engine, but does anyone have a better idea?
Many Thanks
Old May 17, 2015
Re: Dizzy Leak
Is it filling the distributor housing and dist cap with oil?
Is it a valve cover gasket leak?
Is it lacking sealant between the halves of the exposed journal?
Old May 19, 2015
Re: Dizzy Leak
I should have mentioned, it's a newly rebuilt block and head with ARP head bolts and brand new gaskets all around.
No oil enters the dizzy and the oil is dripping from under the distributor.
On the other hand I'm not sure what an exposed journal is and I tried to look it up. It has something to do with the cam, but I'm still a little confused on where to look.
Old May 19, 2015
Re: Dizzy Leak
Ok,,,,, I can't SEE what's leaking on your engine.... Is the hole for the dist round, not gouged or damaged, no huge scrapes the O ring can't seal up? Edges line up?
Here are a couple of the common things people miss....
Google images here, generic
Cam Journal upper half, showing where sealant is applied so oil doesn't seep out between the exposed sections of aluminum:
^^^ This has to be done to the first and last journals only. Those are the only ones exposed to the outside.
And...
Missing sealant at the sharp corners on the valve cover gasket
Old May 20, 2015
Re: Dizzy Leak
Awesome. Now that is something I didn't check. I'm not sure when I will have time to check it, but that is a great suggestion. It definitely makes a lot of sense. If I have time over the weekend I'll check and let you know what I find out.
GritzNGravy
Aug 19, 2015 03:03 AM
cukaracha
30
Jul 26, 2015 12:01 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 16, 2015 10:14 PM
Causemo
Jul 5, 2015 06:42 AM
