92 lx no fuel no spark please help
Ok my car was fine, I parked it 2 days and it won't start.
I've got no fuel and no spark.
All fuses are fine.
If I jump #5 the fuel pump primes
If I jump #1 the fuel pump primes
Can't pull codes, the cel is stuck on and won't blink when I jump the 2 wire connector by the ecu.
Any ideas? Thanks
All fuses are fine.
Any ideas? Thanks
Re: 92 lx no fuel no spark please help
I came to this conclusion because when you turn the key on the fuel pump does not prime, and when you crank it there is no spark. After googling it, it seems to be a common problem on civics of this gen. It's happened to a bunch of people. None of which ever had a real fix. One it was the main relay, so I changed it and nothing. Etc.
If you can jumper it to make the pump run, then IMO you OUGHT to be able to test to figure out why the main relay is not being triggered at the right times. Wiring diagram and volt meter to begin.....
Green02civic
Jul 27, 2015 10:48 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
