1995 Civic Hatchback VX Vtec-E Knocking at Low RPM
Old May 31, 2016
alisuygu's Avatar
alisuygu is an unknown quantity at this point
Hi! I was wondering if someone might have experienced something similar and could offer advice on what might be causing the noise. We have a 1995 Civic Hatchback VX Vtec-E that makes a knocking noise at low rpm. Once it passes 2500 rpm, the knocking is completely gone and everything is perfectly fine. It doesn't seem to bog performance at all, but it's annoying, nonetheless. The timing belt and water pump were replaced 40k miles ago as well as the clutch, so not sure that is the issue. Anyone have experience with this low rpm knocking?
Old May 31, 2016
Re: 1995 Civic Hatchback VX Vtec-E Knocking at Low RPM
You might post up some video of it making the noise.... along with showing how to make it make the noise like blipping the throttle, acceleration, decelerating, etc.
Old May 31, 2016
alisuygu's Avatar
Originally Posted by ezone
You might post up some video of it making the noise.... along with showing how to make it make the noise like blipping the throttle, acceleration, decelerating, et c.
Here ya go! First time I've uploaded to YouTube lol. It happens from 2000 to 2500rpm and immediately stops after.
https://youtu.be/-ArqmJS9HLc
Old May 31, 2016
Old May 31, 2016
Did it get run low on oil?
Is the oil very low now?
If the answer is yes to either question, that's bad.
Based on the crappy sound reproduction qualities of this laptop in front of me, my assessment and opinion is: Stick a fork in it, it's done.
Sounds like a rod bearing is wiped out.
Please have an experienced professional inspect and verify this, live and in person.
DIY:
It was thumping pretty loud at idle.
You can try disabling one cylinder at a time (unplug injector connector or remove plug wire) to see if there is any change in the knock noise, this can at least narrow it down to a single cylinder if you drop the pan to check deeper (bearing inspection)
If no difference is heard at idle, then prop the throttle open to an RPM where the noise is louder and repeat the same thing.
When you find the one that makes the noise get quieter, that's the bad one. Note it for later.
Got metal in the oil? (drain it into a clean pan and look)
Got metal in the oil filter? (cut it open and spread out the filter media to inspect)
Drop the pan and look for a pile of metal in the center
Then look at the rod caps, is one a different color from the other three? Remove the discolored one, it should be the same one that you determined was the source of the knock in the earlier steps.
Old May 31, 2016
alisuygu's Avatar
It's scheduled to go to a mechanic on Friday. So, when you say it's done, you're thinking the engine is shot? Never had low oil or been run low on oil.
Old May 31, 2016
On my crummy laptop it sounded consistent with a rod (bearing) knock.
At 2000 or whatever RPM it becomes loudest, it sounds like a piston is contacting the cylinder head (because the rod bearing is wiped out)
If this turns out to be true, it needs an engine job.
Used engines can usually be found, cheaper than repairing the original.
But as said before, have a competent professional evaluate it.
Old Jun 1, 2016
alisuygu's Avatar
In your opinion, if we're looking for mileage, what's the best engine to replace this with that would be legal and pass smog?
Old Jun 1, 2016
If you're talking about California...........simplest way is to install an engine that is exactly identical to what you have now.
If your car came with (for example, because IDK which engine is supposed to be in your particular car) a D15B7 from the factory, replace with the same engine. If you have to reuse your original manifolds and whatnot, do it. All you're really using another engine for is the good block (rotating assembly) and head....everything bolted to it can be swapped over if needed.
OptimisticWay
Jan 3, 2016 07:54 AM
rford65
Nov 22, 2015 11:22 AM
badyellowvette
Nov 19, 2015 10:04 AM
Hawleywood
Nov 15, 2015 12:16 AM
Bilal Ather
Transmission
Oct 22, 2015 07:04 PM
