1982 Honda Civic DL 1500 rear suspension bushings
Hi there. Me and my son are new to this forum. We just bought a 1982 Honda Civic DL 1500 hatchback and starting the process of fixing it up. So the car runs good but definitely needs some work to get it perfect. Will be pulling the motor and rebuilding that after we addressed some other issues starting with the rear suspension bushings. So the ones they call Bush a and bush c. I believe the part numbers are 52382 692 004 and 52383 692 004 and both are the same on the passenger side and the driver side in the rear. I can find all the front ones these rear ones seem to be very elusive. Besides the exhaust and a couple other little things this is the only real outside engine part we need to deal with. So just curious if anyone knows where to find an actual OEM part or an aftermarket part or if there’s someway for these to be rebuilt. The ones On the driver side seem to be OK but the ones on the passenger side are worn enough that the tire leans and shakes a little bit. So we want to start there and then more after that so any help is appreciated thank you
mfskarphedin
23
Jan 17, 2015 10:34 PM
Joe32288
Dec 6, 2009 09:45 AM
93 civic eg
Oct 11, 2009 08:57 PM
