98 Honda Civic in limp mode won't pass 3500 rpm
Rep Power: 0 98 Honda Civic in limp mode won't pass 3500 rpm
Hello everyone, my 1998 honda civic has been in limp mode and won't pass 3500 rpm. It's throwing the code p0335 which is the crankshaft position sensor, I brought it to a mechanic and we changed the crankshaft position sensor with a duralast brand as well as the timing belt, but it's still stuck in limp mode and still throwing the code p0335
I also tried replacing the ecu and still no luck.
About 2 months ago I changed the distributor because it was misfiring, but after I changed the distributor the misfiring stopped and then my car became limp mode.
Car specs:
1998 Honda civic Dx
Automatic
d16y
Not sure what I should do next, please help. Thanks
Car specs:
1998 Honda civic Dx
Automatic
d16y
Re: 98 Honda Civic in limp mode won't pass 3500 rpm
You all need to understand that 3 different sensors are inside the distributor, one of those is CKP.
You don't see a connection here?
FWIW aftermarket distributors are crap.
Rep Power: 0 Re: 98 Honda Civic in limp mode won't pass 3500 rpm
I was thinking about that it had to do with after replacing the distributor, but since it was throwing a p0335 code I wasn't too sure. I'll take it back to the shop and tell him about it.
Ramrod
07-30-2018 11:19 PM
Malaci
10-12-2017 08:33 AM
Rhonda Dupree
08-01-2017 10:55 PM
Phantomd
09-18-2012 10:27 PM
Psyotik123
04-08-2009 01:34 AM
