Idle surges when engine is warm, low engine temp or IAC or FITV
I have a 1995 1.5L Civic Dx 4 door. The car starts up fine, but when the engine warms up the idle surges and drops repeatedly. I read on some threads that it could be the IACV, or the FITV, or leaky vacuum hoses, or air bubble in coolant. I checked the first three, and did not find any problems; I cleaned out the IACV, but the idle surging/dropping continues. I have noticed that the engine temperature is lower than normal, about 1/3 of the way on the gauge, or just below the 1/2-way mark. I wonder if this is causig the idle? How can I check the coolant temperature sensor with a volt meter? Also, there are no check engine lights. Unfortunately, I do not have a shop manual, so I am getting all my repair information from online. Thanks.
Re: Idle surges when engine is warm, low engine temp or IAC or FITV
Let it sit and run until the radiator fan comes on....Coolant temp should be about 195-200F or so when the fan kicks on.
See where your gauge is at and see if the idle is stable at that time.
Kenny McClendon
Nov 28, 2019 09:01 PM
PlzHelp
Feb 1, 2018 08:55 PM
askem27
Jun 11, 2012 02:49 PM
NO FAME2
Feb 5, 2012 01:09 AM
leonhsieh
Jul 11, 2005 10:05 AM
