95 Civic not start
Old Feb 11, 2018
civic1995's Avatar
civic1995 is an unknown quantity at this point
95 Civic not start
Problem is intermittent. Vehicle will run fine for two weeks then not start for a day. Have spark at plugs. Have pulse at injectors. Have tried a couple relays they all behave the same. When vehicle will not start fuel pump will not run. We can jump relay 5 to 7 and fuel pump will run but vehicle will still not start. All other readings in and out of relay seem to be normal. Have checked ground wires and everything seems ok. Any suggestions? Ecu keeping something from coming together? Could it be something in the switch? Thanks for the help.
Old Feb 12, 2018
mac25's Avatar
Dr Krieger of Modification
Re: 95 Civic not start
Do the other systems got voltage when you turn the ignition switch and it doesn't work?
It could be the ignition switch
-Does the battery need to be jumped when it fails?
-does the starter engage?
-power to gauge cluster?
Old Feb 12, 2018
civic1995's Avatar
Battery does not need jumped. Starter engages every time. Not sure about gauge cluster will have to check next time it does not start. Thanks.
Old Feb 12, 2018
civic1995's Avatar
Everything gets voltage except where 7 leaves relay going to fuel pump.
jdawgzcivic
Engine start problems
Jul 20, 2020 10:57 PM
honvic
30
May 10, 2019 04:35 PM
Dobber1
Feb 17, 2012 09:43 PM
Swifty
Canada West
Dec 8, 2002 05:13 AM
WhiteRabbit
Oct 12, 2002 07:52 PM
