Wet rear and front passenger floor 95' Civic
Old Sep 23, 2019
beneditti's Avatar
beneditti is an unknown quantity at this point
Unhappy Wet rear and front passenger floor 95' Civic
This has been an ongoing problem with my car. Our Summer in WA just finished (yep, its September and it's already getting colder and raining at ton), so this has started again.
I've noticed that right underneath of my front passenger and rear passenger's carpet gets really wet once it's been raining for a few days.
Window seals look fine, except for that black plastic trim part that runs vertically in between the windows. It's popped off on the top.
I have done some research but it seems like this issue for most people is happening in their trunk and/or on the driver side. My driver's side has always been dry.
I will try to get that trim popped back in with some sealant around it, but in the mean time does anybody have a suggestion?
Thank you!
Old Sep 23, 2019
GolNat's Avatar
Prelude Owner
Re: Wet rear and front passenger floor 95' Civic
Leaks can be hard to pinpoint as they can come from a place you wouldn’t suspect. I would remove the carpet so it can dry out and with the carpet out you might be able to see a water trail. You can start just randomly sealing things but that could take a while. I would start by fixing that piece that has popped off.
Old Jul 10, 2020
luckybiker's Avatar
luckybiker is an unknown quantity at this point
I had a similar problem with my '94 civic cx. Found it was leaking into the heater intake under the cowling on the passenger side and constructed various dams which seem to be working. I glued my trim back in place with windshield sealant. Good Luck
SlimRisk
Nov 9, 2011 10:40 AM
Irish97
Jun 15, 2010 05:05 PM
cb450sc
Aug 18, 2009 10:32 PM
bluericeburna2k2
Dec 1, 2003 12:50 AM
FSRbikr98
Sep 1, 2003 03:50 AM
