Honda Civic 1992 not turning over
Old Jun 30, 2019
Alex White-cruz's Avatar
Alex White-cruz is an unknown quantity at this point
Idk what the issue or issues are but I got the starter and alternator tested there both good. Just bought a new battery so it’s not that. I’m not really knowledgeable about Honda’s but the lights do come on if I take the terminals off and on and I’ll try to crank it over and the lights don’t come back on I’ll have to mess with the terminals again to have the dash lights come on
Old Jun 30, 2019
Colin42's Avatar
Re: Honda Civic 1992 not turning over
So there's a bad connection somewhere. Make sure everything is clean tight and shiny. I had one car where the bad connection was where the wire came out of the terminal clamp. If you get someone to try cranking the car and start feeling the wires you might be able to feel the bad connection because it will be warm
Old Jul 1, 2019
Slumpertcivic's Avatar
My first guess would be the actual switch the ignition key turns.
If called the “steering” switch and you can test the contacts pretty easily.
halo5ive
Mar 6, 2018 01:06 PM
cukaracha
Oct 23, 2016 05:18 PM
yajstylez
Dec 1, 2014 10:39 PM
BRBRT03
Dec 3, 2013 11:59 AM
mpgnotwhp
Feb 23, 2012 09:46 AM
