Squeeling/grinding noise from passenger rear tire
Rep Power: 0 Squeeling/grinding noise from passenger rear tire
Hello, im having a little hard time figuring out why my car is making such a horrible noise. The noise sounds similar to a squeak combined with a grind. The noise is coming from the passanger rear tire area. It happens while driving. If i come to a complete stop, the noise stops. But itll come back eventually. Any suggustions help.
Re: Squeeling/grinding noise from passenger rear tire
Is this about your Jaguar, or the Daimler?
What year again?
(EDIT: yeah. I did it.)
Have you:
Raised wheel off the ground and spun it to see if it makes noise?
Investigated said noise- if you can duplicate it easily?
Checked the brakes?
Check for rocks or something stuck in it?
Rust chunks grinding?
What year again?
Have you:
Checked the brakes?
