Engine continue to run with brake pedal applied. No joy with ignition switch
Old Sep 2, 2019
khraviation's Avatar
khraviation is an unknown quantity at this point
My 1991 Honda Civic SI has been with me since new. It has 295000 miles on it. I had an issue a month ago, when I turned off the ignition switch, the engine continued to run until I took my right foot off the brake. I have changed the brake switch, the rubber stopper pad on the brake pedal, the ECU, ( I have a few spare parts ), and the parking brake light switch. The car runs great, but it will not shut down as long as the brake pedal is applied. The brake lights work great with the pedal and new switch when the key is off, so I am starting to believe there is a feedback through something electronic... The Integrated Control Unit, the automatic seat belt motor... Anyone else ever see this issue?
Old Sep 2, 2019
Re: Engine continue to run with brake pedal applied. No joy with ignition switch
And the ignition switch...
Old Sep 2, 2019
Finally found the issue. I studied the schematic for the closest combination of the two different systems. Found it on the right fender. The main circuit breaker system had both system wires within 3/8 inch of each other cleaned the old grease out of the connector, and the terminals, and put clean Dielectric grease, and it now works again as the manufacturer intended.
Old Sep 3, 2019
glad you got it solved.
I had nothing on that.
Sleepy3rd
Brakes
Aug 16, 2019 07:04 PM
TiggerDX
Jun 18, 2015 01:43 PM
angelmar06
Oct 14, 2012 09:06 AM
D16z6
May 23, 2012 09:59 PM
Civic2k2Rider
19
Oct 8, 2002 04:34 PM
