Window getting loose, repair procedure?
Old Apr 2, 2018
eddiearni's Avatar
eddiearni is an unknown quantity at this point
Hi, I've got a 91 DX hatchback.
My driver side window is loose.
Specifically, it rocks back and forth, as on a fulcrum.
To create a seal when I roll the window up, I have to pull it back and push it out a little just to make it fit.
I intend to take off the door panel and do whatever surgery I need to do to fix it.
What might I expect to see here? What might the problem be, structurally? Has anyone seen this issue, and what goes into fixing it?
Thanks
eddiearni
Old Apr 7, 2018
mhammond1127's Avatar
mhammond1127 is an unknown quantity at this point
Re: Window getting loose, repair procedure?
Thanks
eddiearni
Take the plastic door cover off, really easy just need a flathead and Phillips head screwdriver and there’s probably a video on YouTube that will explain how to more in depth. Your window is probably off the track a little bit, which is easy to fix (again there’s DIY videos on YouTube that should be able to help)
Robin17
Legal Questions and the Law
Jul 19, 2016 11:25 AM
CivicVTec
42
Mar 24, 2005 11:44 PM
RobG2k1
Apr 11, 2003 12:04 AM
CivicPunker17
Jul 2, 2002 09:33 PM
klam
Detailing
Jun 9, 2002 07:25 PM
